Boot Build
Work has started... Well its stripped anyway
Not MUCH work... but its a start :)
  • Replies 8
  • Views 1.7k
Crikey iv got compertition! lol
Mines is being finished as we speak!
What you got planned for yours???
erm.. can i see a plastic connector block connecting your amp ??
mmmmm fire hazard. get it in a proper FUSED distrubution block!
adskiv - ull be done b4 mine :) not certain on plans yet...
Foxie.. I know ;) Rewire at the weekend... :)
I'm gonna put a 2nd battery in the boot... What gage wire do you suggest to connect them together? And would you need to fuse that?
Or just fuse the amp?
Bassically gonna have ALL my ice of this one batter (3 10" JL Audio Amps, Couple of Speakers somewhere)
Not completly sure of the make up of it all.. But want to start the wiring soon....
To run the 3 amps, you need atleast a 4awg cable from the battery, then id use a 4 into 1 fused connection block with some 40 amp glass fuses! :thumbsup:
Thanks mate..
Don't really want a forest fire in my boot 8-)
Insulation.... I know you can buy that special insulating stuff...
BUT.. whats the difference with that and me putting in 2 layers of carpet beneath the MDF base and the metal?
I don't want to spend money if I don't need to... But don't want it to sound bad...
Any ideas :)
Edited by cptbob
Flashing tape from Screwfix.com will sort you right out for sound insulation... ;)
