clutches
are the clutches the same between 1.0 and 1.3???
there was a newish one fitted to a HZ engine i;ve got sat in the garage but will this fit on a 2G?
  • Views 835
I've found out the clutch i;ve got spare is 180mm
and a new one for my current setup is 190mm.
will it make any difference if i use the 180mm in my 1.3 with a 4 spd box ?
