interchangeable parts between gt and g40
ok can anyone help me with this:
driveshafts - are they the same?
ARB - the same?
Is it a neccesity to run g40 TCAs on a g40?
Crankshaft - the same?
Downpipe- is it the same?
is there much difference in the loom?
fuel pumps - the same?
radiator- the same?
is the head the same just a different cam?
thermostat housing the same?
dizzy is it the same?
mounts excluding the charger bracket the same?
alternator the same?
injectors the same?
  • Views 2.1k
the heads are the same If i can remember, dunno bout the rest though
Yeah, heads the same bar cam and sodium filled exhaust valves, I'd imagine the antiroll bars are the same, no need for a diference, driveshafts may be different, but don't take it as gospel. most of the other things you mentioned are different.
Mike
driveshafts - are they the same? one is different i think not sure which one.
ARB - same
Is it a neccesity to run g40 TCAs on a g40? personal opinion. i'd say no but they're probably better.
Crankshaft - the same? not 100% but i dont think so
is there much difference in the loom? not loads but... knock sensor??
fuel pumps - the same? yes py/nz/3f share the smae pumps
radiator- the same? yes and no. py has seperate part number but both are exactly the same against popular belief they're different. anyone who can PROVE the difference please let me know i'll be intrigued.
is the head the same just a different cam? different, cam and valves
thermostat housing the same? same
dizzy is it the same? same
mounts excluding the charger bracket the same? yes the same, although PY does have a seperate part number for the front gearbox mount but both are the same but look very slightly different
alternator the same? yes
injectors the same? no
alternators are g40 specific
they are arnt they!! yeah cos they mount totally different. thanks for that. well spotted.
GT and G40 radiators are the same, as are the dizzys and fuel pumps.
Crankshafts are G40 only (unless you can find a mk2 diesel engine), so you might as well buy a conversion rather than building one up.
driveshafts - are they the same? NO G40 ones are very slightly shorter, but any other mk3 ones will do
ARB - the same? YES
Is it a neccesity to run g40 TCAs on a g40? NO
Crankshaft - the same? Dont Know
Downpipe- is it the same? No
is there much difference in the loom? throttle position switches and knock sensor I think
fuel pumps - the same? YES
radiator- the same? YES
is the head the same just a different cam? Valves are different
thermostat housing the same? YES
dizzy is it the same? YES
mounts excluding the charger bracket the same? Dont Know
alternator the same? NO
injectors the same? NO
