removing rear wiper ! HELP
took my rear wiper off and cant find anything big enough to fit in to fill the hole
what have people used ? its a 30mm hole
  • Views 1.3k
I bought a set of Halfords grommits, the largest one in the set was a perfect fit.
yep same, it was black so i colour coded it, rubber doesnt take that well to normal spray paint :? or do it properly and have a plate tacked on the back then fill it. depends on how far you want to go really.
Edited by polopete
I was gona make a comment about struggling to fill a hole... but i won't.
As above halforsd are the best place for things like grommets, unless you're handy with a welder... Otherwise you could get the bootlid in to the bodyshop for some smoothing work doing to remove all trace of a rear wiper hole.
sorted it now got a blamking grommit from halfords!!
p.s i dont think a welding on glass would be pretty :lol:
