Missing hose on a 1989 1.95
I was having a clean around the engine bay on the van, and I decided to take the airbox off to get in the nooks and crannys. I thought I'd got all the hoses off, lifted the flysing saucer up, and there was a half inch rubber hose hanging down from the base (comes out inside the air filter element).
Any ideas where it's supposed to go to? :-(
  • Views 1k
its likely to be the crankcase breather hose that goes to the back of the engine
Thanks fot the help. That certainly sounds like a likely candidate. Whereabouts on the back is it (centre/left/right)? Easy or a bit of a pain to spot?
I'm a bit of a stranger to this particular sort of polo engine, I keep catching the back of my hand on the fuel pump forgetting it's on the right :roll:
goes straight down to the back of the engine where it goes to the dome on the back of the block. there should be a hose coming off the pipe to the back of the rocker cover too
Thanks for that. I've got the little one, it's just this one that's been catching me out.
