Refitting Arches and Sills
Is there a VAG part or a type of adhesive strip required for the re-fitting of arches and sills?
When I removed mine I spent days cleaning the old stuff off - but it did do a good job!
Does it simply stop the arches / sills from vibrating on the paintwork and damaging it?
Dave
  • Replies 14
  • Views 1.6k
i just bought a new vag, passenger side arch for my Gt and it comes with the holes for the rivets and where the bump strip sticks out there is a adhesive fixer on there.
I dont think there is a vag part for the adhesive, but I'm sure any industrial adhesive/double sided tape or even some silicone sealer would do the trick.
Does it run the whole way down the sill?
I'll grab some later,
Dave
I used sikaflex before on my old GT. But if you use that dont expect to get it all off the car in the future!
no-nails!
I went to vag and they gave me some double sided black tape stuff, looked awefully like license plate tape no matter how many times they said it wasnt!
It lasted all of about 4 days!
Then i heard the lovely sound of it falling off when driving!
Nice one vw!!
Chris
yup, no more nails! I'm gonna try it on my arches and see what happens.
use tigerseal body sealent......
I used this tape that i got from work....
3M™ Acrylic Foam Tape
A versatile, double sided foam tape for critical fixing applications, and made from high density acrylic foam. Supplied as rolls in 0.8mm and 1.1mm thicknesses and a choice of 6 widths from 6mm to 50mm.
lol that last sentance looks very copy and pasted lol and they sell taht stuff at home base its used fo sticking lino in awquard places i think :retard:
I think VW used to put a 'sealing cord' on the mating surfaces of bolt-on panels, like the wings. Similarly, the contact areas where the bolts are located have a piece of zinc foil placed in-between, to stop the two parts rusting together.
'non-hardening sealing tape': D001 600 05
'Packing strip (zinc)': AKL 381 035 50
It's spelled sentence :oops::lol: .....and your right. :thumbsup:
opsey i no how to spell it usually i think it was just because i was typing quickly maybe :x:oops: :oops: :lol:
hi there, when i enquired at vw recently in leics to get a new rear plastic arch on my mk3 due to a crack, i was laughed at an told they dont do them anymore, so if you could advise on where abouts you got yours from then I'd greatly appreciate it!.......
Actually, its 'spelt' sentence. Spelled isnt a word as far as i know ;)
