what size tyres
I know 50's or 55's but looking at either 165/65 or 175/65 on 13's with ET35 or 38
If/when it get dropped prolly only 40mm will either of these combinations cause any rubbing.
PS I have searched but found no mention of the above comnbo in the faq
TIA
  • Replies 8
  • Views 1.7k
I think its fair to say on a 40mm drop you shouldn't have any scrubbing issues running 165's or 175's on 13's.
165 and 175 are the standard widths for GT & G40's and i've mine lowered 40 & 60mm on standard wheels and even with a full load i.e. 5 up i had no scrubbing issues so you should be fine.
Thx for that Stuey, just picked up 4 175/65 Uniroyal's get em fitted tomorrow :smile:
175/65 is slightly bigger than the standard G40 size of 175/60. They shouldn't cause any problems on a Coupe down 40mm though.
yeah should be fine with 175/65 as toby says.
Let me know what there like for grip as i'm gunna be looking for some standard size 13 inch tyres shortly for me new bbs once they are refurbed.
do u think 14"rims with low profile tyers with 40mm lowering would rub i was hoping for seom 15" but my mate told me they would rub like mad
Will do, they were the reasonable priced name brand rather than ditchfinders or champiros :-D
Wnnt for the 65's as the rolling radius is more or less identical to the std 145/80's
14's for you
http://www.clubpolo.co.uk/forum/index.php?...mp;#entry676047
Edited by beemer
From experience red-rocket you should also be fine with 14's low profile tyres and a 40 mm drop. I'm running 60/40 H8R kit (lower than most 40 kits) with some 195/45/14's and i have no rubbing issues. The tyres are conti sport contacts which appear slightly wider than my previous Toyo T1-R's but still no issues.
15's and mk3's are a whole different ball game. Its either a case of running 165/50's or 175/50's or 185/45's and pray. Otherwise arch work will be needed. Had 15's on my mk3 previously and even with 195/45's, with a passenger or a large bump in the road you could feel them ripping into the arches. I now have flat spots on the plastic linings. A skinner tyre should help you down to around 60mm after that again you would need more arch work. Hope that helps.
cheers mate that really helped was going to put my lowering springs on but it pissing it down :angry:
thanks again buddy
alex
