Rattling Noise
i keep hearing some rattling noises in my car the main 1 is from the clocks none of the dials are loose there all working fine only happens when driving along and stops if i touch the glas protector thing.
and the 2nd one is from the left door, i think front 1 again only when I'm driving.
anyone know why this maybe? would be great if i get some suggestions pissin me right off whn I'm driving to work in the mornings....
and when i start the car i get this noise when theres no revs as soon as i hit 10000 revs its fine but just below it the car vibrates and stuff is that normal for an mk4? or somethin dodgey?
Cheers...
Kidd
  • Views 1.6k
i ahve a noise coming from the back passenger side area dontno if its inside or out but its only when i go round a corner??
~BUMP~ still needing help! noise is gettin on my nerves when driving with a head ache
Hmm only thing i could suggest for the clocks would be to take them out and make sure its all tightened up, also give it a shake and you'll probably hear the problem easily enough and then find some way to fix it from there :)
As for the passenger door it wouldn't hurt to look behind the doorcard see if anythings loose, i found a whole lot of crap in the bottom of my door :p
Not exactly answers but hopefully it'l help you find some :)
oh and polokidlee, not sure but i had a grinding noise comming from the back of my car when going round corners, turnt out to be suspension related if that helps?
Edited by TheBadger
cheers badger will try that anything to stop tha noise :)
hey polokidee i had the same problem too when i went around corners!! i called the AA out to have a look at it and it turned out to be an extremly loose bracket supporting part of the exhaust! might be that, hope it helps :lol:
  • 2 years later...
the problem in the door is more than likely the window winder prise the cover off and its just a philips head to tighten up. i had the same problem and couldnt for the life of me figure out what it was until a buddy of mine put his hand on it and it stopped haha.
