Engine Sensors on a MK3 Gt
As the title says. Basically I'm having problems with my car and trying to figure out what it is.
I would like to know what sensors the are? what do they do? and where they are on the engine?
Thanks!
  • Views 1k
Throttle potentiometer> throttle position
Blue temp sensor> Engine temp
Lambda sensor> air/fuel ratio
Air flow meter> self explanitory (also air temp)
Hall sensor> cam position
Right.. Awsome. Where is the hall sensor loctaed? I know where the rest are.. but just to confirm on the throttle potentiometer, its on the TB (a little black clip, opposite side to the air box)
Hall sender is part of/on top of the dizzy and can be a right bitch to change and is considered easier to replace the dizzy. Not impossible though.
cool.. can anyone confirm the throttle potentiometer?
Yes, it's on the throttle body spindle shaft.
