brake upgrade
i cant click that lik you posted?
  • Replies 30
  • Views 3.1k
So these, Tarox G88 Front Discs Mk2 G60 280mm BR-DI-FD-280-TAR-0202G88 would fit a valver on standard calipers? Where do you get carriers from?
Try the normal places forums, scrap yard, vw
can i have a list of what you need please as i would like to get theis done as soon as posible as the pads are getting on the thin side anong with the disks
this has come up many times...
G60 Caliper carriers
G60 Calipers
G60 brake hoses
16v Hubs
G60 Discs
G60/16v pads (same IIRC)
OR
G60 Caliper Carriers
16v Calipers with the slider pin heads shaved 2mm
16v brake hoses
16v hubs
G60 discs
G60/16v pads
obviously if you already have a 16v then u can scratch those parts from the list
yer thanks ate an di did a search but then CP stopped working for me so i ddnt do it again lol
rite I've found everything i need... its just brake hoses which ones do i get?
HOSE SET 1
HOSE SET 2
thanks
