Will These Fit On A Mk3 GT??
Would these fit striahgt on, i want the 7x13 for front, and 8x13 on rear. sorry if this has been asked.
http://www.wellerwheels.co.uk/catalog/105-...ort-362364.html
also if it is possible what size tyres do i need for them to have a stretched look. will be pulling the arch 10mm out.
Edited by pologtonATSclassics
  • Replies 11
  • Views 1.6k
dont go for the 8"s they have a stupily low offset, 13x7 all round look spot on with the wellers
175/50/13
You're gonna need ones with a stud spacing of 4x100 aswell, or need wobble bolts to get them on. Clicky!
thanks. ille get 7's all round.
howmuch archwork is needed with 7's? I'm getting the arches pulled 10mm and rolled. will they be fine after this?
I want some of these sooo much...
tbh with the 7"s you wont need to pull the arches maybe just get them rolled.
my arches are pulled 10mm and rolled and have 7"s on the front and they dont rub at all..
8-)
Before i buy 4 of these aswell, they say there for Fords, is the centre bore the same as the polo?? I've got a MK3 Coupe 1991/2
Nope Ford centre bore is something like 63mm, you need 57. Probably need to get spigot rings made up if you can't buy them.
anyone know of any other links to websites that sell nice lookin steelies? those wellers are rad!
regards to the bore siza, that sucks, i want those ones... where else sells them...
Added::::
I've emailed WellerWheels asking if they can get the correct fitment for the MK3 Polo, so ill let you all know when i do.
Edited by Messydan
From what I can see from their website, they do not have one suitable for a the Polo. The closest is 7-13 ET 3, this will fit if you have Gr.H style arches
Their 8-13 is ET minus 12
Here's a pic of my rolled arches and 8-13 ET 18, weller would stick out 30mm more
Edited by G40NUT
In your opinion (and other members)would the 7x13 ET+3 stick out too much.
I'm still waiting for comfirmation from Weller on the 57mm bore.
