VW II Caliper Bolt Question
Yes people
Just put some VWII Calipers on my gt coupe. (I'm running it with the VWI Carriers)
I went to gsf to buy some new bolts as the old ones were shot.
I was then told that they require 2 different sized bolts for the caliper (one slightly longer than the other)
Is this true? If so does the long one go at the top or at the bottom of the caliper? Sorry to sound like a nonce but this one has gone straight over my head...
thanks in advance
Adam
  • Views 1.3k
Yes people
thanks in advance
Adam
it be true, i dont remember the correct way though.
before you bolt the caliper to the carrier drop the bolts in place they both need to stick out the bottom the same length should be easy to tell from that
Rob
The longer bolt goes in the top.
its true 1 long 1short long 1 goes on top
