Fat wellers! help please...
Hi i am looking to buy a set of weller steels this week and was thinking maybe 7x13 front and 8x13 rear i want a wider set for the rear if you get me. Anyway i have a mk4 6n polo 4 stud.
I'm not to hot on wheels and I'm just a bit worried that these wont fit in some way can someone please have a look and see what they think.
Front
Size: 7 x 13
Stud Spacing: 4 Stud x 108.00mm (4.25 inches)
2nd Stud Spacing: 4 Stud x 100mm
Back Depth: 100mm
Offset: +3
Centre Hole: 65.0mm
Rear
Size: 8 x 13
Back Depth: 100mm
Offset: -10
Centre Hole: 65.0mm
As you can see the rear offset is quite mad but any help is appreciated.
Cheers guys.
  • Replies 12
  • Views 1.8k
anybody? :(
is your car lowered? standard arches :-)
Will rub to fook without 4x4 ride height
VW centre bore is 57.1 I think, Those rear's are maddd, you'll never get them in the arches without and work, offset of 15 on 8's is bad enough on mine, those are -10. (Not many wheels comes with an offset of minus's) 4x4 ride height and you'll be fine :roll:.
Even lowered 80mm, the arch gap would be so big it probably wouldnt even rub.
They will stick out LOADS, both front and back with those offsets!
8x13 et-10 is insane!
The inner rim of that 8x13 will be half inch further away from the suspension,so the outer rim is going to stick out three inches wider than a 5.5in wide VW rim would.
is it possible then? weller do a 7x13 wheel with an offset of +3 would that be more suited?
Iv got a set of coilies from you mate so it is quite a major drop.
I have those wellers on my mk3, the 8 x 13's -10 offset on the front, 13 x 9 -10 offset on the back.
They stick out miles but they look sweet!
I put the 8's on my mates ibiza cupra last night and they stick out way past his arches, it rubbed like mad (and considering he has 9 x 16's under there normally with no problem his arches have been rolled to cope with width.
8's (these are running 27mm spacers as my brakes are pretty large, so take an inch off them sticking out)
They look quality though mate!!
Chris
awesome! thats what i lookin for. do you think il be ok then with my mk4 polo?
You know they're wide when you can see the second row of tread from above! You know they're totally illegal,too. There are some great fibre arches available for those.
