MK3 blower resister capacities???
hey guys,
The blower resister has blown about a week ago, and instead of replacing he entire unit, i think i might just replace the 2 blow resisters.
just want to know if anyone know the capacities of them?
also where is the actually resister block located???
  • Views 1k
it's under the plastic scuttel panel under the bonnet drivers side ,i looked at replacing the resistor wire with diodes but was told that solder would not hold the diodes on the terminals as the wire is curenly welded ? and solder would just melt ohm's reading is also very low sorry can't remember off hand and cant check mine now as already on the second or 3rd twist of my wire due to breaks
Rob
Rob
Cool, thanks, i'll get the old haynes manuel out when i get home.
Mike
