Window.. How to remove them!
As the title says.. I've got my eye out for tinted windows... When I find them how do I remove them? I know how to remove the front door quarters and thats it.. how do I do the..
Windscreen
rear boot
Rear quarters
Front door windows
  • Replies 8
  • Views 1.6k
uberfukz has put a bit of a description in his thread as i wanted to know this also...
Thanks for that, but I didn't understand that? Anyone else got anything a tad clearer?
erm.. i didnt get it neither tahts y i told you to look at it and not me typing it out lol but purr the rubber down with a screwdriver (flat head) and slowly push the window over it and it will pop out... i cracked one as it didi pop out so with two of you it shouldnt be that bad hope tahst abit clearer lol
Yeah.. kinda!
front side windows are pretty simple. just remove the doorcard and it should be obvious which bolts to undo. Once you got the opening window and seals off and unbolted the bar behind the quarter light, it'll slide backwards and out.
Rear side windows will pop out if you push the corner hard enough with your feet from inside the car.
Windscreen is technically possible by pushing it out but chances are you'll break it. I'd cut the seal and replace it, or if you arent bothered about breaking the glass then try pushing it out with your feet again.
The coupe rear window is bonded in and is a job for a professional to remove and re-bond in. Again, unless you dont mind breaking the old window.
Hammer works a treat :p
o bugger is it not possible to refit coupe windows yourself?
Hayesey, your a lege!
I always wondered how the back windoe stayed on!!
anyone know where to get the window seals from? gsf?
