gt throttlebody
hello, i have just de wedged my throttle body, but i was just wondering what method is best for porting it.
thanks
  • Views 1.3k
Speak to Yoof.
Not sure if he is still doing the service or not.
But he would send you a larger one for exchange for money plus your old one.
use a carbide burr in a flexible shaft on a dremel and a flap wheel. you can probbaly get a carbide burr and flap wheel off ebay for £10 and it takes about an hour and a half to do a throttlebody (well thats how long I can do them in).
And does thsi make a difference?
the driveability is generally improved when using part throttle, but it wont give you any more power, because the secondary bore can supply enough air for the engine once its open.
Edited by optima21
Certainly seems to pull better I found... A good mod IMHO!
cheers boys
how do you do it then... how much do you remove?
