Where do you advise me to stick my jack?
Ok here's a simple question from a total moron;
In order to change the fuel tank I have to jack the rear up, remove the wheel and drop the beam.
My question is - since I have to drop the beam, what point should I use to jack up and support the rear of the car?
:-o
  • Views 1.2k
:-o
You could use the sill jacking points - but will need to jack the car on the axle to fit the axle stands under the sill jacking points...
Easy enough - I always use an old towel i cut in half now for any jacking or axle stand jobs - for piece of mind and protection...
When you have removed the wheels - place them under the sills too so if it falls off and you are working underneath - you wont be squashed!
Thanks, man. I probably deserve to be squashed for my ineptitude!! :badgrin:
