1.3 GT turbo?
Has anyone on here ever done the above? iv heard a fair bit about turbo'ing a G40 engine but is this also possible on the GT engine with all the correct parts, inlet manifold, downpipe etc?
i may be wrong but are they not the same engine apart from the camshaft and obviously the charger, and mapped different?
If its a viable alternative to a G40 ill look into going down that route :-)
all advice much appreciated.
cheers
Greg 8-)
  • Views 1.9k
it depends on your definiation of viable. its possible, using a G40 to start off with would be a better option.
The biggest difference is a G40 is 8:1 compression and a GT is 10:1. You could turbo a GT, even at that compression, if you can get enough fuel in. That's the hard part... making sure you don't melt pistons.
The easiest and therefore cheapest way is with a G40 lump. ben999 (I think) is selling a freshly rebuilt G40 engine for £500 in the for sale section. This would be an ideal base, and PSD are selling turbo parts now.
yup thats right Fully rebuilt....... close with the name matey "benh999"
Bargaaaaaain at £500 considering it cost that much for most of the rebuild!!!!
Edited by benh999
