Fitting aftermarket foglamps to standard switch...
I am thinking of buying a set of aftermarket foglamps. Is it possible to replace the standard light switch (as mine came without fogs) with another one (6n one) that has the foglight switch built in and connect these foglights to it? If so, is there any modification needed to be done on the socket that plugs into the switch?
Just trying not to use the switch that come with the fogs...
  • Views 1.2k
get hold of a fog light headlight switch then i believe its the 14th pin that you need to wire it onto, i'm sure theres a guide floating about somwhere!
Didn't the 6n fogs come wired like the 6n2?
still searching for the guide but can't find it, all I found is a mk3 guide...
