side strips
When removing the rubber strips, what are the chances for taking the paint off with it?
  • Views 967
May be some chance if you just rip them off. But if you a careful and heat them up with a hairdryer or a heat gun it softens the glue behind them. You can then use some fishing wire behind the strips and start a sawing motion. After that you will be left with some spongey glue then just clean that off with a solvent of some sort. Same applies for removing badges.
Yer i got the badges off with the help of 1 of my mates who owns his own business. So as long as I use a heat gun/hair dryer/anything that gives off heat, it should be ok as I dont have the money to get a respray or put some paint on (yes I am that low :sad: )
