Fuel tank problem
Today my fuel tank decided it would spit some fuel out of the car :shock: I have been having some troubles with fuel smell in the car & today it was really strong but once investigating found that there was petrol coming out of the overflow pipe and a puddle sitting in the rubber bit around the filler neck! I checked the breather pipes and there all ok & not blocked...
Any ideas? :cry:
  • Views 1.2k
Popular Days
Any ideas? :cry:
If you found a pudle round the breather neck then its coming out through your filler cap, check the seal hasn't perished and dissappeared.
The breather that comes out of the neck go's up through a u-bend in the inner wing before the fumes are suck back through the pipe to the front of the car to be ingested by the charcole filter then feed to the engine(if its all original).
