ATS classic help
i have a 91 mk3 polo gt. will ats classics 7x13 on the front and 8x13 on the rear fit straight on?
the arches are getting rolled and pulled 10mm front and rear.
I also want some lo-profile streched tyres, without going ott with the streching. what size tyres will be best for this?
the car will be lowered aprox 80mm on coilies, or lower if possible.
thanks. h
  • Views 1.5k
Fronts will be fine. Backs should be ok too if your rolling the arches. Someone will be able to tell you for sure. 175/50 will be best for the fronts. Then you could either use the 175/50 on the backs which would give a good stretch, but if you don't want so much, maybe a 195/45. You may need 175/50s so you don't rub though.
Sure someone will be along soon enough with photos to show the stretch.
Hope thats of some help
thanks that helps alot, 175/50 is perfect for me. any pics of the 175/50 tyres on 13's? thanks for the help
Edited by pologtonATSclassics
on coilies which are stiff as fook you should be ok but you will need to get the arch return lips rolled up, not necessarily flared.
I'd not be putting 175s on an 8in rim. And neither would my tyre shop. 195x45 on the back. Stretch will match the 175s on the front then,aswell.
Haha 175s on an 8 good luck
adskivw's are 175's i think? they look VERY tight
