how do I stop the headunit turning off when I start the engine?
I have re-wired my head unit so it always stays on, however when i start the car it goes of for about a sec, how do I stop this,
hu is sony mex-bt2500
  • Replies 10
  • Views 2.2k
i dont think its possible to be honest.
that headunits good tho init. got that handsfree kit built in. down side is theres no pre-outs or owt
The power draw from starting the engine requires all available current.
oh yea, make sense,
yea the head unit is kool, looks classy too, not all flashy flashy like pioneers, not as good as mex-bt5000 but for £90 on ebay its a bargain.
mine doesnt, its an old shite headunit from a mk4, probably doesnt require as much power as yours.
you could fit a capacitor into the power input of the headunit (its is sometimes done as a quickfix to stop headunit from flashing when running at high volume (esp. noticeable at night) it might work, it might not but its worth a try
depends if the cap would store the charge for long periods with the engine off? I'm not that clued up on caps but i think they lose power over time.
they do but it does take a long while if there is no load on them
right, caps will stay charged to battery voltage at all times, they don't lose power ;)
the headunit will not like the voltage drop when cranking, just as a try out, i would not use the cars poxy power and earth, try running a power and earth in 20 - 30 amp cable direct to the battery, this should stop your issues i think! also check your vehicle earth straps both to body and engine as these will cause bigger voltage drops when starting :)
try this and report back!
I believe sometimes a red top battery can cure this.
why would you want to go through all the hassle to stop this happening in the first place dude?
seems pretty pointless just to a cure a second or so of no music.. :?
