For people with angels on the MK4..
Hi All,
I have been driving on the motorway quite a bit these days, sometimes in the dark, and have noticed that I cannot see much with the angel headlamps even with the Xenon bulbs...Does anybody else have this problem? Any way to get more light??
Cheers.
  • Views 1.5k
Hi All,
Cheers.
notta problem here.. and i run with yellow tinted headlamp covers. mayb they need re aligning?
I don't think they can be alligned! Do you think it could be becaus I took the sidelight bulb out? I doubt it.
Got any pics with the yellow...
not sure but mine were fitted at a garage..
bad shot but only one i can find.... cheers will. ;)
maybe uprate your headlight wiring loom?
think theres a sticky somewhere on the site about this, but in all honesty it should be fine :?
... maybe you need HID's :D
dont think u can fit HIDs in these lamps.... mayb wrong tho.
are they the ultra ones with sonar on them. if they are i had the same problem with mine. first time i went out at night i was having to drive with main beam all the time. it was due to the level was to low just need to adjust them up. (should hav it done rite at a garage although i didnt) as pic shows turn the adjuster nearest the indicator clock wise to adjust the beam level up.
sorry about the poor drawing
lee.
Cheers Lee I'll give it a go. Nice one.
