new discs and pads
its for a 1998 m4 saloon classic. I've looked on gsf and there is way to many. can anyone tell me the part numbers for standard discs and pads and for a better set aswell. thanks.
  • Views 1.6k
tarox do alot of better pads and disks ita ll about you are driving style though but theres fast road, rally, race. uprated road theres loads and the same with disks
they sounds good but seem a bit over budget. I'm really looking for under £100 for discs and pads
is there anything better than standard for not much more?
Edited by stuartswan
:( not tahts of any quality... if youw ant to go that way there was a thred on here called "brake upgrade" and that has a few people saying about disks and pads
I'm not tracking the car and its only got 75bhp so just looking for something better than stock that wont fade
I'm about to order these but want to check if they will fit.
64254 BRAKE PAD SET-PAGID TQ PO Saloon (With 239 x 10mm Discs) 11/95 > 14.50
64288 BRAKE PAD SET-PAGID TQ PO Saloon 11/95 > 21.95
or
62361 BRAKE DISC-12mm-ALT PO Saloon (239 x 12mm Discs) 11/95 > 5.15
64288A BRAKE PAD SET-PAGID PO Saloon 11/95 > 19.50
can anyone tell me if these will fit a 1998 saloon 1.6 and which would be better? also are pads and discs priced singlely or per pair on gsf. thanks
Mintex pads,Brembo discs. Or Ate spira discs (grooved).
