mk5 info
I'm about to buy some new wheel's for my car, what distance are the stud's away from each other and what et do i need what ever that mean's,lol
I'm not very good at this wheel stuff
  • Views 1k
I've got a mk5 on 15'' ronal turbos, they are 4x100, et 32. if you order a set of wheels from someone like rimstyle or demon tweaks thell order the correct spec wheels for you( the correct et, etc) hope this helps mate. :-)
4x100 Is the stud pattern
ET doesn't have to be the same but similar and you'll get a nice fit, search for that on the forum, theres a wkd guide somewhere!
Centre Bore is 57.1
And Finally don't go bigger than 17's and you'll be all good :) What you looking for anyway?
Centre Bore is 57.1
i fancy ats cup's!!
