Tailgate Wiper
hi, another problem, when i switch my rear windscreen wiper on i get the click from the relay and a buzz as if the blade was moving yet no movement can any 1 help?
  • Views 1.3k
check the nut isn't loose on the bottom of the arm just pop the cap but dont tighten too much or it may strip the threads
Rob
Rob
i will try this tonight and will come back to you
Rob
I have tried this morning and last night and couldnt get it to work??
Rob
anybody?
Is the buzz not the water jet? as the motor might be blown. New motor will only be a few quid from scrappers. You could take the rear pannel off and check there is no loose wiring, could just be as simple as a wiring falling off a contact.
if i pull or push the right stalk (one of the push or pull cant remeber) the water sprays out, if i was to press the end of the washer stalk in all i get is the relay click and a buzz
