Removing mk 3 doors
do you simply knock the pin out with a hammer?
also, if so how difficult is it to get the clip back onto the pin when putting them back on?
cheers
if you mean a mk3, made between 1991 and 1994, the doors bolt to the car.
He means the bit that stops the door from opening too wide I think? My dad did it on mine and I wasn't paying any attention but I think he just used some mole grips to push it out and similar to clip it back on. But as I say I was busy doing other things so wasn't paying much attention.
ahh forgot about them, havnt had them on my cars for years now. they can just be tapped out with a hammer from memory
I guess you mean the check straps. They should just tap out with a hammer. If they don,t you can always grind of the arm and get some new ones. If memory serves me correctly there aren't very expensive to get from VW.
I couldn't get mine out with hammering them so I just cut them off :lol:
Ye i mean the "check straps" that stop the door opening too far... i tried hammerin it a bit but didnt get much movement n was thinking if i whack it out i probably won't be able to get it back on - might WD40 it and then try. i'll worry about getting it back on after!! cheers everyone. :thumbsup:
