Mk3 drivers side harness help!
I've got a pair of 4 point harnesses to go into my G40...
I've got the passenger harness all bolted up nicely and sorted, but the drivers side is all fine apart from i cant get to the bolt that holds the red holster (the bit that the belt clips into lol) because its behind the seat subframe!!
Now surely there is a way to get to the bolt, but it looks impossible because its behind the frame!
Surely others have harnesses in their mk3s? i really need some help!
  • Views 952
desperate bump
As I said in the PM, with the seat removed from the car, you can get to the bolt you require my moving the subframe out of the way as it pivots due to the height adjustment.
