Volkswagen fitment on Vauxhalls
Awrite guys
Can somebody tell me if VW fitment wheels with fit a Corsa B?
Ken
  • Views 1.2k
the stud diamiter is the same 4x100 but the centre hub is a different size so will need spigot rings to fit properly.
this might be helpful and will tell you that size they centre hubs are.
wheel things
Thanks man, thats a big help. They're the same pcd and similar offset but vaux are 56.5 centre bore and vw are 57, spigot rings should sort that.
Taa, Ken
offset will be wrong
Vauxhall = 49mm
VW = 35 to 38mm
my mate has 7x15's with 195/45x15 tyres on his Corsa B
there et 45.....so only 4mm out
it's lowered 40mm and the tyres scrub if theres passengers in the rear
if they were 11 or 14mm out the arches would be damaged pretty quickly
Edited by PShears
Vauxhall = 49mm
VW = 35 to 38mm
saying that though....my standard 6n steels have an offset of 43??
Edited by 10Jonesy7
the mk3 golf comes with ET43 wheels as standard too
Well I was thinking of Th Mono's 7x15, which are ET 35. That shouldn't be too bad surely? Only 14mm.
