Wat Size of tyres on 7 x 14's?
In the middle of purchasing a set of borbet t's.
wondering what tyre i should be puttin on them ????
I'm not too bothered about a stretch..
my car is down 80mm
what tyre do i need for it not to shred the arches?
  • Replies 22
  • Views 1.8k
195/40 or 195/45s would look pretty damn good on a 7J me thinks.
is 195 the proper width of tyre for a 7j
as I'm keeping the handling
I'm not wanting you trickin me and gettin a stretch without me aware :lol:
Also!
what size of wheel is on the normal gt
I'm going to try out that wheel tyre size calculator.
195 wont be a stretch on a 14 x 7 rim
good,
would 205's be pushing the boat out?
I'm wantin the profile of the tyre to match what the original wheel was..
I wouldn't put 205s on a Mk3 Polo there is a point where there is too much tyre... ie when its wet and you find yourself aquaplaning everywhere.
195/45 is only 2.5% different to the rolling radius of your standard tyres, keeping gearing and speedo readings accurate.
what about 185/50/14 or 175/50/14... slight stretch, not too wide, shouldnt make too much difference to rolling radius.
2.5 too fast ? or too slow
I'm guessin fast here
what about 50's..
i knew it wouldn't be long before someone tried it :lol:
well if i had 8's on the back i would have...
but i only have 7's all round...
but i think ill be spacing the back if a have room
Theres a reason people run stretched tyres when they have wide wheels. That reason is so they don't foul the arches. Depending on offsets you might get away with 195/45. I really doubt you'll get a 205 under the standard arches though. Specially if its lowered some.
Found out my offset is 15
seems pretty low
so that meaning its gonna look phat ? :p
do you know if the actual wheel will protude the arch ?
anyone else running these wheels?!
offset 15 on a 7j will scrub on the arch spesh lowered 80mm
chap the inside of the arch in...?????????
anyone on here with coupe on same wheels or size?
i hope there isn't too much scrubbin but a little with raise a smile now and again lol
erm i have 195/45/14 on my 14x8 borbet t's so that wrk with nice strech
sorry mk4 6n tho and arches have be pulled by about a inch
gd luck
Edited by polo.6n.max
So your arches are like 30-40mm narrower than that 6n above.
You're going to need stretch. Otherwise its archwork. Even with the cheap and plentiful 185x55x14s (indicated 48.7@50mph) you're going to have problems on the front.
185x50 (indicated 50.4@50mph) is probably your best bet,given the situ.
What you really need though,with an indicated speedo reading of 51.3@50mph and a tidy arch-fit,are 175x50x14s.. :unibrow:
I'm running a set of bbs rms?not to sure on actual type but thats what I'm told . ne ways mine are 14 *7j and I'm running 195/45 speedo says 50 and I'm doin 52 according to sat nav. as to fit they sit under the arch so ne lower and they will rub hope some help came of that :-)
I've never seen a set of 14" RM's. I don't think they ever came in 14"
probs rj's
i think i would rather arch work
stretching is not for me at the moment..
the way i see it 7j is not worth stretchin onto..
8 or 9's! thats more healthy..
ill roll my arches a little :D
195/45/14's from polo1600i will be ordered soon enough :D
as i said i have no idea really what they are but their form around 89 i think as that is stamped on them i will try to get pictures
i dunno i reckon with the right wheel stretching is ok as long as you dont mind the loss of grip
i want to keep as much handling as poss...
but with a small stretch will that not be good for handling ???
in some weird way
less tyre wall movement ??
like 1 size down or something :S?
195 onto an 8 is a very good combination for handling, according to G40NUT.
i quite believe that to be true..
coz people buy lower profile to have less flex in the sidewall..
a stretch is just a cool way to do it
