6n2 door panels
Hi, how do u get the interior door panels of a 6n2 3dr, tryin to fit upgrade speaker behind the original cover an dont want to wreck the panls by tryn to yank them off
Thanks NiCKK
PLEASE ANYBODY HELPP!!!!!!!!!!
Bit of a long process but easy..front and rear?
Drivers Front Door - Screw in the left hand side of the door, unscrew the locking pin, then carefully remove the hand grip cover, there are two screws behind there and if you have manual windows the winder has a cover over the top of it and a screw underneath. Then pull from the bottom of the door, and it should come away, carefully work around the door once off electrics for mirrors need to be unplugged from behind the door....so don't pull it off once you've un clipped it.
Hope that helps mate
Thanks mate, i'll try that tomorrows.
