Mk3 Polo front bumper
got a mk3 passat splitter for the Polo
how do i remove the front bumper?
i haven't got a haynes manual yet :(
please help...
Aaron
  • Views 1.7k
There are three bolts under the grill, So take the grill off (pry it off at the clips on the top of the grill carefully using a blade screwdriver, carefull not to brake the clips)
Then there are two more bolts under the number plate bit (wheer the recess is in the middle of the bumper.
As above VeeDubGeezer, once all bolts are removed, the bumper should slide forward off of the side mounts. I'd put some cloth/protective material on the floor under the bumper dependant on where you are doing it as when the bumper comes off, its just sort of falls off if you know what i mean. Bit of a fiddly job but really very easy.
cool thanks guys :D
Err, you'll probably want to remove the plastic rivets from the wheel arch protectors too before you rip big holes in them.
