Do Revolution Alloys need 'Speacial' Bolts/Studs??
Would a set of 4x100 Revolution alloys need 'speacial' bolts/studs, as in ones with sleave's or anything.
  • Replies 8
  • Views 1.4k
Please help, there is a set near me ending on ebay in 2 days!!!
They're 4x100? What are you worried about? The bolt pattern is fine. So what about the flange? More importantly,the offset? You know wheel sizes,you know what fits, find out the info.
highly irrelevant post, youve cleverly avoided the actual question.
some revolutions need flat based nuts/bolts, others tapered. dont worry about it, you can get a set to suit once youve got them, grayston engineering make wheel bolts/studs in every style so they should do one to sort you out
Revolution say:
PCD: 4x100
Offset Range mm: +21
Backspace mm: 107
Edited by kerrly
your sweet! no worries!!!!
at worse, you'll need some extra bolts, but £20 should fix that, but highly doubt that you would need any other bolts!!
Ford have spherical seats. Peugeot have flat seats. Tell me Pinch,what 4x100 fitment use such seats? And no,I've not seen every fitment. I've not noted the taper on Rover 200 bolts for a start. So its possible. Which is why my post is full of questions
Mikey - they're 4x100? What are you worried about?
Did he say they were or were not VW fitment? Did i say yes they'd be fine? No. Why? Because i cant know that,with the info given. No 'dodging the question' about that.
Perhaps you have all the answers? Tell us Pinch,what bolts is he gonna need? Well,GE wont know unless he buys the wheels. Which kinda defeats the object of his question,doesnt it.
ford with spherical seats? VWs have sperical seats, all the ford wheels I've seen are either flat or 60deg taper.
like i said, buy the wheels and someone will make bolts to suit. different types of revolutions need different bolt/nut seats
