DIY refurb, i need pointers
I'm trying to refurb my centras this afternoon. I've used nitromors and I've got rid of all the laquer, the alloys
arent painted, just laquered straight over the alloy like a lot of oldskool wheels.
There are black bits on the wheel which is salt corrosion, how do i get rid of these marks?
Edited by DubLass
  • Replies 8
  • Views 1.7k
If you can get pics it will be easier to say. I can't make much of your explaination :oops:
I cant at the moment, photobucket is down :-(
I googled it though and got some pics that show what i mean...
You can see it round the edges of these BBS wheels
and more black salt corrosion
what I'd try to do is to sand out the marks till it was back to the good metal. Then if you're painting, prep and paint. As kam says, would be an idea to see the marks and for you to explain the finish you're after.
I just wanted to get the salt marks off the alloys and then have them in the same condition, minus the salt marks.
Here are the wheels I'm on about. (not mine but the same)
You can see the salt marks on most of them...
Edited by DubLass
get them recut, you will have to remove a good mm to get down to the clean metal, theres no other way to do it if you wanna keep the diamond cut finish
Will any refurb place be able to recut them?
most good ones will do, but its not cheap. those wheels look like they would be worth spending the money on them. try pm'ing rocco-jocco he sells a lot of refurbed wheels esp diamond cut ones! he may be able to sort you out
Ahh cool, I've just sent some pictures to a refurb company, see what they quote!
