adaptors for 5x130 alloys to fit 4x100
is it possible to get adaptors for 5x130 alloys to fit vw 4x100
if so any idea on cost etc
  • Views 1.4k
thanks for the links richie
my problem is,the wheels are 8" wide and the smallest adaptors I've found so far are 22mm.
do you know if you can get adaptors less than 22m like 5-10mm max,as i think it 22mm will be to much and push the wheels out way to far
it is not how wide the wheels are you want to worry about it is the ET of the wheel. What is the ET of the wheel you are putting on?
Venom do 15mm ones
get some 20mm ones, you'll be fine!!!
specially as porsches usually have higher offsets!!!
find out the offset 1st and then work out what size adapter you need!!
You can't say that with out knowing the ET of the wheel.
If i had done that i would not have been able to fit my wheels
They're £125 at Rennsport,they look good quality too.
oh and forgot to say 15mm ones are only made by FK
