removing front grille badge from 9n2/3
anyone know how it is done? i tried to turn in and then pull it out but i heard something go snap so i thought i better ask on here
cheers sarah
  • Views 1.5k
I think it might be the same as all the others...The grille comes off then your able to remove the badge.
I had murders with my 9n when I sprayed my standard grille gloss. I used a screwdriver to pri it out. I did break (kind of) one of the clips at the back BUT it still held in place extremely well. Hope this helps??
Oli :thumbsup:
  • 1 year later...
Oli :thumbsup:
hi its very easy 2 take the badge out
1. open the bonnet
2. on the top of the grill there is a torx (star shaped) bolt on each end of the grill, unscrew them.
3. next to the bonnet latching mechanism (in the Middle) there are two clips. you need to release them by pulling back towards you (if they're stiff you can use a flat screwdriver but take great care not to snap them).
4. the whole grill will now lift out in one go.
5. if you look at the back of the grill you will see the badge is held in by 4 clips. push them in again take care not to snap them and push the badge out of the grill.
when you come to reassemble
push the badge back into the hole in the grill
slot the grill back in and retighten the torx screws AND MAKE SURE IT IS SECURE
hope this helps
speedbird 752
