POLO SPEEDO FAILURE
Hi i am a new member to this forum, I have a 1997 polo 1.0, The other day the hole thing stoped working,
No speed
No rpm
no time
no fuel
no temp
no millage
no oil
no brake
no batt
yes mainbeam
yes indicators
Can someone please help me trying to fix this problem and if it is a common problem?????????
Thanks Lara
  • Views 1.3k
Car still starts?
Fuses?
Battery Terminal?
Doesn't sound like a common problem.
Hi + welcome to the forums.
I don't know much about your polo, I'm sure someone more knowledgable with help you out. First though I would check the fuses, could be that simple.
Hope you get it sorted + good luck.
Car still starts?
Fuses?
Battery Terminal?
Hi thanks eh no car starts fine and drives fine fuses all ok batt all ok.....
Sounds a bit wierd, I'm Stumped, next thing I'd think of at this time would be the wiring or the actually unit having something wrong with it...I'm sure someone will be able to help.
Yea i would think that the cable has come loose at the back of the dials mate.
Just take em out and make sure they're plugged in :)
Welcome to clubpolo :D
