electric windows
hey,
got a problem with my electric windows on my mk4;
they seem to get stuck wen they are going up but go down fine and the only way to make them go up is to push the glass towards the front of the car...
was wondering if this was a common problem and if anyone knows of any ideas bout how to fix it???
any help appreciated,
thnku, Nelly :-D
Edited by polo_nelly
  • Views 1.3k
very common prob! it will be either the regulator or the clips that hold the window one. either way you will have to fit a new regulator(s) as its all one part. its a bit of a fiddle but not impossible for the competant diy'er
Tank you mista :-D x
you would be suprised how easy it is to take the electric windows out and put them back in
what is the easiest way to get round all the insulation? i am finding myself limited as to what i can do because i dont really want to rip all of the insulation off? or is there another way?
thanks
extremely common problem! i cant be arsed fixing mine so i just lube up the edges every now and again with some good old wd40! make sure u clean the glass properly afterwards though!
