Petrol Leak
Hi Guys,
I have a petrol leak, it appears to drip from around the rear wheel on the drivers side, does this sound like where the fuel filter is or the fuel pump? Its a 1990 Polo Coupe if that helps lol.
John
  • Views 1.4k
Most likely where the filler neck joins the tank. Have you had a look under there, what can you see?
Just had a look under now i think its the fuel filter is that the big cylinder and the pump is the small cylinder?
Yeah, the fattest of the cylinders (next to the spare wheel well) is the fuel filter. Far cheaper than fuel tank, that's for sure. £5 and 20 minutes...job done.
