mK3 clocks Wtf
Hello
Right yesterday i took my clocks out to paint the needles, on reasemble the fuel gauge and temp work, the led bulbs for warnings work, the lights work, the LCD clock works but the speedo and rev counter does not work,
For ref i didnt take the needles off i simply guarded behind them with white paper.
Any help will be cool
Scott
  • Views 1.4k
the speedo works of the speedo cable so double check that you have it pluged in correctly. not sure about the rev counter.
Right, just went for a little drive, They didnt work, then i went over a bump quite hard then they both started working, Pulled up went in to house, came back out started up then they didnt work, drove back home and wen i got into drive way they started working again.?
its deffo bad location of the speedo, if they dont go in perfectly they tend to become very on/offish! on one of my polos i could hit the dashboard and they would start working again
push the clocks proper hard into their place. probably not pushed in properly. dont crack the plastic though lol.
HA yeh, I had it out again, and made sure the connector plug was pushed propper in, Put it back togeter then it still didnt work, Slapped the dash and they kicked in, Will pop out in a sec and make sure the spring clips are in propperly.
Cheers Folks
