16v brake upgrade
hi i need to get some new pads and dics soon and i was thinking of getting somthing a bit better that standard what should i get an I'm not looking to spend big bucks.
links would be helpful.
thanks
sam
  • Views 895
the basic upgrade would be getting some decent discs and pads, green stuff pads are recormended discs wise i beleive thers some cheap brembo on gsfcarparts.com
or looking at a better option is a g60 brake upgrade wer you change the discs to 280mm, you basicaly get hold of the g60 carriers and swap them with your existing 256mm carriers then buy g60 pads and discs generally the same price as te valver ones bobs you are uncle you have 280mm brakes.
but to do that mod u need at least 15inch wheels
thanks i wont be going down the rout of the g60 caliper becaues I'm gettin my stanard valver wheels diamond cut.
thanks for the help.
i think i get a discount form gse right for being a club mender?
If GSF still sell Pagid fast road pads, I can recommend them. Cheap and very effective. Don't get anything fancy for the discs, good quality standard discs work fine.
yer I'm just gona go with the brembo max disc and the green stuff pads it only £50 all in
