Rear Washer Jet
The rear washer jet on my valver doesnt seem to be working, i think its blocked as when i push the stalk forward, water comes out the front jets as if theres some pressure build up. Its not blocked around the rear tailgate but from the tailgate, where does the pipe run and how do i get at it to check. dont really wanna spend a weekend removing random panels looking for it
  • Views 1.2k
runs along the passenger side of the car under the door iirc. youll find it in the boot if you take off the plastic panel!
it's built into the rear wiper motor...
when this happened to mine it had popped out off under the washer bottle, just off the motor check round ther mate
ah yeah the pipe also pops off sometimes.. mine was under the rear passenger side door card! just check to see its still connected!
i got the same prob, might try some of that, not that i use the rear wiper ne more... lol
Fixed mine on saturday, as predicted the hose for the rear jet had popped of under the bonnet just by the pump. had to take the battery out to give my hands a bit more space to work but rammed the hose back in, stuck a circlip on it to make sure it doesnt happen again and all is good! Do like seeing whats behind me - esp if it has blue lights on it!!!
