Lenso wheels
hi guys, i have seen these wheels but I'm not so sure if they would fit my polo without any arch work!!
the size of the wheels is this 205/45/16" 7.0X16 4X100/114 ET38 GMM and here is a pic, can anyone help please
  • Views 1.5k
Hey there
Not sure if they,'ll fit or not, but I got a set of Lenso JL02, 205/40/R17. Needed a bit of work, back went on ok, but front needed 20mm spacers as there were rubbing on coilovers. Apart form a bit of handy work cutting away some of the plastice gaurds on the inside and a little rubbing on big bumps.
Tbh 17's probably a bit to big, as I've already got a 40 drop on it and cant get any lower as wheels are to wide, so I'm going back to 15's as i've got a new body kit going on, and i'l llooks bit strange being sat so high.
Hope this helps
P10GOT
The only bit of advice I can give is I have these wheels on mine and they are 15's and mine is dropped 40mm and to be honest there isnt loads of room left, I would say you might just get away with 16's, going off mine, but I am no expert this is just my opinion! :-D
a girl i kno has 16's on a mk4 with 195/40/16 it is lowered a fair amount but she has verry little arch scrub i think a 205/45 would be too big but the only way to realy tell is to put them on and see.
