Speaker Sizes
Right thinking of a sound upgrade
i need the sizes for front door speakers and the dash speakers cheers
thanks
PS MK4 polo lol
  • Views 1.6k
front door speakers are 6.52 or 17cm. The ones in the dash are 10cm i think.
cheers chap
i did try my 10cm infinitys in the front but they were to big (i did only try for about 3mins tho)
I think the ones in the dash are tweeters. Usually OK as standard but the door speakers are rubbish replace them and you will notice a big improvement.
Wire your dash speakers and door speakers seperate unless your using components of course, as the standard stuff is in series. like i say though, thats if you want to run 2 sets of coaxial speakers.
the plastic grilles on the doors just unclip and pull out don't they?
  • 2 years later...
yeh just use a flat head screw driver or as i got told you can get a 2litre bottle and cut a square out of it and cut it round the speaker mesh and pop it off (Y)
carefulon the dash mesh tho the clips snap real easy, i have 8cm fly speakers in dash dont forget to rewire tho else ul blow them when cranking volume up as i found out the hard way with the first set.
