Sunroof
If anyone has the following or some advice to help my leaky polo!
MK2 polo with pop-up Sunroof and the handle doesn't quite shut and compresses the rubber and lets water in so either of the following options.
1: Need a replacement handle but the company that do the handle went bust.
2: whole sunroof from someone breaking a polo.
3: another sunroof for a golf or simular that is the same size :?
Edited by residentmelon
  • Views 1.5k
Bump!!! Anyone
is this a vw pop up or after market version?
Is it actually broken,or can it be adjusted,repaired etc.
If its a standard VW glass sunroof,you'll have to track one in scrap yards.
If its an aftermarket roof,and the company who made it have gone bust,you're without a paddle..
Options there would include getting a sunroof company out and fit a new one slightly bigger,or bonding the glass permanently closed using a strip of universal window seal (like that rubber strip round many car/machine windows.
  • 2 years later...
yea this is still the problem on my 6n, go to your local VW dealership and get a new rubber seal, as after a while the rubber goes soft and the sunroof doesnt seal on the corners properly.
Or just go to a scrappy and find a thicker sunroofseal, may be trial and error though with fitting then just glue it down.
