Manual window = FAILED!
Sorry if its in the wrong section! wasn't sure where to put it.
Well my drivers side window winding mechanism has failed, by that i dont mean my arm, has fallen off, no, its the runner/glass clap part. here's a bady drawn diagram to explain!
As the picture shows, its very gay. The little gray thing keeps popping out of the clamp that holds the glass, so then the windows isnt attached to the runner properly and its mighty tough to put the window to the top, and its fallen down off both runners on one occasion good job it was dry, thought the glass had smashed though!
So after figuring this out, i set about trying to hold the clamp and plastic thing together, i used a little bit of silicone sealant, which went everywhere but where i wanted it to go, so failed and the window came off again, so i tried again, this time i got the bastard, 2 huge lumps of silicone all over the grey plastic and the clamp. Still no joy, when i initially tried winding the window up and down after "fixing" it, it was fine, totally smooth, but I've got a feeling its come off again as its gone stiff near the top again.
Has anyone else has this problem? as it really is doing my nut in! I've also tried getting a self tapper in the plastic behind the clap no no effect, the smallest screw i had just kept falling into the door, and i couldn't drill a small hole to give it something to grab to, as everything is attached in the car so space is a minimum.
Thank you! Rob. :)
could you not trying getting the whole mechanism out? Then could simply put a self tapper in
p.s. nice picture ;)
Not tried it, but its seems like a hell of an effort to try and squeeze everything out through the tiny tiny access holes!
:D :D Taa mate :lol: I'm a paint pro! 8-) :cool:
