Mk3 Tyre Pressure
What pressures are people running on the Mk3's ?
Edited by StevieDavison
  • Views 1.7k
Iirc the correct pressure is 32psi, that's what I run mine at anyway.
Sal. x
I'm running 28 front, 24 rear, I think they should be 26 on standard steels.
2.1 bar all round, should be plenty
On a normal tyres around 30 if its stretched around 32 should do it.
155/70 R13 (standard set up): 25psi all round.
But up to 35psi on the rear and 30psi on the front with a full payload.
Daniel's right for 155's. Lower pressure helps em go round corners.
175's, I just go with the universal "whack 30 in em all" approach.
Quick tip: Stick about 40-45 in the spare. That way if you forget to check it, it's not flat when you need it.
Edited by Yeti
I dont have a spare man but thats a good point ... Spare wouldnt fit in the well ..
