headlight wiring and angel eyes
when i switch On the sidelights only with the ignition On the angel eyes light up, but so does the dipped beam a little bit.
is there any way to disable the dipped beam and have the angel eyes on only , when switch is set to sidelight.
would i have to rewire at the switch? or is this something i cannot change.
thanks
  • Views 789
Popular Days
cant change that mate, unless you begin pissing around with the relays an crap
best thing to do if you just want the angels on is to wire them direct to the battery with a separate switch for them on the dash somewhere, an just use the lights as normal
