noob wants bass
ok so i have standard speakers in my 6n and a kenwood headunit kdc-4060rg i have the manuals if i need to look to see if it has something ? anyways back to the point i want some bass not expensive just a good quility setup for a full sound not super load or anything just nice lol
do i need an amp?
been recomended base tubes with built in amp as i would be taking it in and out of th car quite alot as i carry bikes about quite abit
is there a better option buget about 100 but i will be buying 2nd hand so ebay it up with links if you want
  • Views 926
If your after a bass tube, then look for a vibe. Also depends on how you like your bass and what you listen to, light and punchy dance music you will want a sealed enclosure. IF you want lots of low extension then you want a ported box. If you want a bit of both then a bandpass.
If you get an active bass tube such as the vibes then you wont need an amp. If you go for a separate sub you will need an amp.
Your looking for something like this:
http://cgi.ebay.co.uk/Vibe-CBR12-Car-Subwo...1QQcmdZViewItem
Item number: 290156869589
With a wiring kit like this to hook it all up with:
http://cgi.ebay.co.uk/Amp-Wiring-Kit-4AWG-...VQQcmdZViewItem
Item number: 270106855477
I think you'll find that sealed boxes can drop low too depending on size of the enclosure.... ported do drop harder though... more bass extension around the selected frequency for box tuning..... as for bandpass... dont buy the vibe ac series.. i had one for about a week and sold it.. was totally dissapointed. It dropped well but only with a very small minority of songs. bandpass can be very effective if the enclosure is built correctly (less room for mistake in comparison to ported or sealed)... i think the main factors are budget and how much space u have...hope that helps and just wanted to say the jbl woofers are great on a budget! The cbrs are pretty decent but for the cash i think the jbl sub/amp package is better http://caraudiosecurity.com/shop/product/p...ts_id/1233.html
Abdul 8-)
Just realised you need the sub/amp to be removable... screw the amp onto the enclosure and use this to save the hassle when removing sub/amp http://caraudiosecurity.com/shop/product/p...ts_id/1829.html
Edited by big_k
